Corner toilet, run waste along an inside wall?
7 Feb 2021
Hi, I'm redoing an ensuite and ideally would fit a corner toilet. It's on an outside wall but there's an existing 4" waste 500mm along the wall from the corner, inside. Do you think it's viable to connect to that existing waste using a flexi waste and angles, inside? Or using a 45 degrees and two 90's? Or do I really have to drill a new 4" hole right next to the new corner toilet and fill in the old one? What do you think? Thanks.
The wastes are ideally meant to carry ****, not look like ****! Do it properly, make a new hole.
Let me understand this better, you want to make it travel for a metre, before it enters the soil pipe?
The soil downpipe on the outside is a fixture, at the moment there is a 4" pipe through the wall to it, where the old toilet was. Now I want to use a corner toilet, which is 500mm along from where the old one was. So my choice is whether to run internally, if that is even possible with the angles, or drill a new 4" hole to suit the corner and fill in the old hole. I can box in the internal pipework. My main uncertainty is about the angles the pipe has to go through, behind the toilet, i.e. 135 degrees, and I take Mottie's point about doing it properly.
Drill a new hole to suit and heed Mottie’s advice which I concur.
