My kitchen project has been stalled for some time now and the reason is the cornice I bought for the top of the wall cabinets, The straight bits went fine, but where I needed a 45º cut for the corners I got problems.
I tried a common mitre box but the problem is that the cornice is effectively standing on a thin strip and there is no easy way to kniw one is holding it upright and steady, and ensure a clean accurate cut. The cut I got didn't fit the second piece of cornice properly and threatened hours of file/sand & retry.
I spotted a Coveasy guide at the Screwfix site and got one to see if it would solve the problem, but it clearly is for a specific coving shape only and isn't helping (I have coving to do when I get around to it so it won't be wasted, but the cornice is still an issue).
So I'm stuck again.
Can someone suggest how the job is done so I ensure it is upright as it will be in situ to get an accurate cut first time in the cornice please ? Is there a jig out there which allows this to happen with ease, or is there some other way to achieve it ?
Thanks in advance.
So I'm stuck again.
Thanks in advance.
