Cornice problem
30 Jun 2005
Hi Fellas,
I have to fit my cornice along my cabinets but my wall is nearly 3 metres while my cornice is only 2.4 metres whats the best way to cut so i can join a piece onto the end without the cut being too noticeable?
be worth remmebering where the main door way is into the kitchen,i normally check this so the mitre is facing away from the main doorway or keep the cuts behind you as you enter.and depending on the colour i have even just done a straight cut and used colorfil to blend or white silicone.
Thats what i cant work out how to do without it being noticed. Ihave seen it where the cut has been done on an angle, but maybe the only solution is to use colourfill?[/code]
