- Joined
- 11 Dec 2007
- Messages
- 400
- Reaction score
- 2
- Country
Inhibitor:
Story short, was able to get the plumber to put in some inhibitor today (yes i know it sounds like a task - story short)...
When i got home i noticed he'd left the inhibitor bottle by the boiler & i'm just wondering if it's enough.
It's a 500ml bottle stamped up as 4Trade & says minimum dosage rate is 500ml per 100litre system capacity.
Now i've no idea how much juice is in my system. I have upstairs - 1 towel rad, 2 single panel single convector rads at approx 1.7mtr-x-0.6mtr, 1 rad approx 750mm-x-600mm single panel single convector.
Downstairs is 1x 1800x600mm double-double, 2x 700-x-600 double-double, 2x 900-x-600mm double-double.
10mm pipe work feeding the rads.
Just wondering if it's enough or not.
Lockshield valve cap:
I've had a fair amount of work done & the rads needed to come off. Somehow the lockshield cap has gone missing to the big rad in the living room.
The TRV is stamped up as danfoss & i'm guessing they come in pairs so the other end will be a danfoss valve.
The bit that you'll have to tighten/open with pliers is threaded inside for a screw if this helps.
If you need photos then i can sort this out tomorrow but is there any chance anyone would be able to link up to what i'd need here?
Thanks.
Thanks.
