Hi this is my first post, hopefully the question isn't too obvious?
I moved into a house in December and after about 3 weeks the boiler developed a fault.
It is as Worcester 28Si II, once it has been on for a couple of hours and the radiators are hot, the boiler shuts off and the fault light flashes (approx once per second), the manual says it is either boiler overheat or ignition lockout. After about an hour the boiler can be reset and runs again, until it stops with the same problem.
I have measured the size of all radiators and looking at various catalogues, I have worked out we have total radiators of approx 6.9KW, plus whatever heat losses the pipework will have.
Having looked at the manual for the boiler, it says the minimum heat output for the boiler is 8.1KW. Is it be possible that even at it's lowest output, the boiler is a bit too big for the job and is overheating?
It does provide hot water without any problems, so I would guess the gas valve and fan etc are working ok.
Hopefully someone could help answer this.
Many thanks
James.
Many thanks
James.
