Hi, I live in a house with an old Glow-worm Galaxie 240/6 backboiler. It works fine, the programming system is over-simplistic but it's workable until I can change to a newer system. However, the boiler is starting to get a bit noisy when either the hot water or hot water+central heating are on. I think I've figured out what treatments I may use to try and help, but I just want to know about the correct way to apply them. I'm thinking:
1) Drain and refill with Sentinel X400 System Restorer - will remove metal deposits from the radiators and pipework, I'll leave it in for the maximum of 4 weeks as it's an old system, and then flush and refill with clean water
2) A week later, drain again and refill with Sentinel X200 Noise Reducer - I believe this will concentrate on limescale within the boiler itself rather than the metal deposits in the radiators, so needs this second step? Again, leave in for a few weeks and then flush and refill with clean water
3) After another week, drain again and refill with Fermox MB-1 protector (would use Sentinel, but I know where there's an unopened bottle of MB-1 so would rather use this to save a few quid). This would then stay within the system to add protection and hopefully prevent the buildup of both metal deposits and limescale throughout the system.
Does that sound sensible? I know normally the X200 would be left in, but I would rather not mix chemicals, particularly from two different manufacturers, the results may be unknown and undesirable. But I think if I drain the X200 and fill with MB-1, that'll do the job of long-term protection anyway? The long-term aim is to replace the boiler with a combi, but that means quite a lot of disruption and expense, so I'd rather spend a relatively small amount of money trying to improve the boiler I have until I'm better prepared to upgrade. As far as I know there's nothing wrong with the boiler other than it's shortly due for a service so I'll try and tie everything in together.
Cheers!
Cheers!
