correct order to skim a room
10 Dec 2008
Norwich
I am going to be skimming a small room, just wondered is there an order in which to do the walls? ie, opposite, clockwise etc don't want to mess the internal corners up
Cheers
Andy
avoid wet corners!!!
in other words skim opposite walls and reveals* first.
an experienced spread will not be able to wait for opposite walls to go off so wet angles or corners is unavoidable.
*you would say, do the window side reveals first then do the head later on.
p.s. a right handed spread works left to right starting at the top left corner of each wall. ;)
