You can use those - you need two - but they rely on a decent contact between the pipe and the brass nut on the back of the thermostat. They are extremely slow reacting to changes in temperature. I have also found that they are not very accurate - had two which read different temperatures when adjacent on the same pipe.
For the same cost you can get a digital infrared thermometer, which give instant readings - and you only need one. The only thing to remember is that you should hold the gun as close to the pipe as possible. This is the area covered by the sensor gets larger as you get further away - like a torch beam. The laser pointer is redundant when you are close to the pipe.
That could be because they have been around much longer than the IR type; not because they are better.they are that slow the trade has been using them a lot longer than electronic toys
play nicely fella
i stick with what i know that works
play nicely fella
and iv'e never heard so much **** for a while
