Hi all,
Final step in our renovations is to sort out the insulation in a timber frame 'overhang' section of my daughters bedroom. The rest of the house is brick and overall this section is relatively small.
The make up appears to be the timber frame with c.50mm of fibreglass insulation between that has generally just been done badly, dropped in places etc. Inside there appears to be a VPL between the timber frame and plasterboard, externally it appears to be timber cladding fixed to the battens with a small vented space (you can see the vents at the bottom).
So the question is, what is the correct method for insulating this area to modern standard? There is absolute zero appetite to change anything internally, so all needs to be done from the outside.
1. Remove timber cladding and fibreglass insulation, fit PIR between timbers (foaming joints etc), breathable paper and then new cladding. This option to me feels like the timbers would remain a cold bridge. Would this option require a vented space on the external side?
2. As per 1, but overlay something like 25mm PIR on the outside of the timbers before cladding. I can see how this would reduce the timbers being a cold bridge but I always thought the overlay needed to be on the inside (something to do with dew point?). Would this need vented space again?
3. Something else?
Thanks in advance for any suggestions.
3. Something else?
