Hi All,
After some advice if I may regarding taking power to my existing outbuilding..
I already have power to the shed, but it is done a very crude fashion and I am now looking to do the job properly.
At present I have an armored cable essentially plugged into a kitchen socket, taken out through the external wall into the garden, dug into the ground running through the garden and then coming up into my shed where it is then wired into a triple socket.
From said triple socket I have a couple of lights plugged in..
What this essentially is of course is an extension lead running from the kitchen to the shed..
Whilst this setup works for me, it is very rudimental and I suspect far from 'legal'.. It works and has suited my needs to date.
Following the rough winter we have just had there was some water damage to the shed, so I have taken the opportunity to make some changes and the electrics will be one of them.
What I would like to achieve is a more correct setup with the power in the shed feeding two lighting circuits (via switches), a wall mounted panel heater and then a stand alone double socket.
I of course already have the armored cable running from the house to the shed, but I am now looking for some advice as the best / correct way to a) take power from the house to the shed via the cable and b) what I then should have in the shed to handle the power coming in and the circuits running off of it..
Hope all of that makes sense, but of not please say and I will try and explain!
Thanks for any help you may be able to offer me guys.
