Hello there
I'm seeking advice on the correct way to wire up a Salus RT300RF thermostat. My boiler is an old Glow-worm model which had a standard type room stat wired in series on the live feed from the timer control to the boiler. This involved just the two wires - live and neutral. The earth wire was not employed and was just tucked away inside the room stat's casing.
I'm a bit stuck on the correct way to connect the wireless receiver of the Salus. The instructions that came with it are confusing me (see picture).
I assume I should do it the 230v application way (top diagram). Is it a simple matter of connecting the live (red) feed from the timer to the connector marked L and the black wire to the connector marked SL?
This leaves the problem of the neutral connection at the bottom. The only wire that I have available is the earth wire. Should I use it as a neutral connection?
Any advice would be greatly appreciated!
Chris
Chris
