Hello All
Have just found this forum and looks like a great place to ask this question!
Im in the middle of renovating a 100ish year old ground floor conversion and would like to tackle the problem of severe floorslope (caused by subsidence a long time ago).
At the moment I would like to level the kitchen floor which at present has a 10 - 15cm drop at one side of the room. Work has been done in the past to deal with the subsidence. Steel beams have been added to support the joists in some areas which was revealed by lifting floorboards). Unfortunately this work did not rectify the problem of the slope but seems to have been aimed at halting more downward movement (building has sagged in the middle).
Anyway enough of the sob story. I would like to level the floor without too much fuss and definitely not removing joists so I can have a flat kitchen floor for new kitchen etc. So do I -
1. Bolt doublers onto the existing joists to make them all even. Then refit tounge and grove floorboards or treated chipboard pannels (not sure about these for a kitchen?)
2. Lift floorboards. Cut battens/wedges to lay on joists to make them level
then refit floorboards. Reckon this would be tricky to get right as each joist needs different ammount of correction...
3. Sod the fact the house has character but does not have one right angle in it and sell it and buy a new house that I can afford even less.
Eventually want to lay a rubber/marmolium floor as final finish.
What do you think?
Worried about condensation issues if I just build another floor on top of old one plus not a very robust solution I think.
Will post how I get on.
Cheers!
What do you think?
Cheers!
