Just over a year ago we had a partial update on our heating system - a 3 bed 1960’s semi, 10 rads. We had an unvented hot water cylinder fitted and the system was converted to a sealed one, doing away with the loft tanks. Our boiler was fine so we kept that - it’s a 20 odd year old Potterton profile 60E.
When the work was done the sysem was drained, some descaler added and the system was run for a couple of weeks (we went on holiday). They then returned, drained it again and power flushed it. Corrosion inhibitor was then added. Job done.
However, since then I have had one leak from a rad valve (replaced it myself), plus three of the last remaining original 50 year old rads upstairs replaced (two leaking and just one remaining so changed that as well). I’m now decorating the landing and when I removed the landing radiator, there was evidence of a slight leak on the back of it so for what a 600x600 single rad cost, I changed that too.
Now, my question: all these rads being changed and topping up the system has obviously diluted the corrosion inhibitor. I have a 1 litre of Sentinal X100 inhibitor. Is it okay to add the whole 1 litre to the system? It won’t overdose it, will it?
