Help please.
5 years ago we hade custom made aluminium door frames in our kitchen leading to a stairway. One of the door frames now is showing a small area of corrosion right against the joint to the wall.
The corrosion takes the form of a soft white dry putty like substance which appears to ooze from the joint between the frame itself and the wall. It goes to a semi powder when removed. It also takes the paint off the door frame and there is evidence that the metal is being eaten away underneath.
What can be causing this? the structure the door is fixed to is a brick wall finished with plaster. More importantly what can be done now to prevent this corrosion spreading before it completely ruins the door frame? It was very expensive and I don't relish having to replace it.
Any suggestions or help most welcomed.
