Corsa 1998 Startup Problems?? Help!!
10 May 2009
Midlothian
Hi everyone, Hope you can help me?
I have a 1998 1.0 Corsa Breeze.
Recently had the EGR Valve, Lambda Sensor and Mass Air Flow Sensor all replaced with new ones.
Had a full service and MOT Passed fine,
However, ever since I had the replacement parts put in, the car doesn't start properly.
When its cold it starts fine, but after I get in drive it, then go away and come back on the same day it does not start very well, it struggles to get to its tick over at just under 1000rpm, and sometimes cut out completely.
Any ideas what could be causing it, Had a Scan done for fault codes but nothing is showing .
Thanks all..
Chris
