Hi I have just recently replaced the front brake pads on my 12 yr old P regged 1.2 LS Corsa. since then the pedal has gone really soft and needs pumping to get the brakes working.
I did pump the brakes after fitting the new pads, but its almost like they relax back in to the caliper the next time you try the brakes after 5 minutes ?
I have searched the web and there are some suggestions that as I did not release the bleed nipples prior to pushing the caliper pistons back, that i may have rolled back the cup seals in the Master Cylinder ?
I understand the theory behind this, but find it hard to believe that it is possible as the forces needed to apply the brakes should be greater than the force of fluid pushed back through the system by a caliper clamp
If this is the case is it possible to dismantle the Master Cylinder and re-position the seals or does it need a new Master Cylinder ?
All suggestions Welcome Thank you
