Cost of Cavity Wall insulation
5 Sep 2006
We have the Builders working in our House
They have taken down an internal Wall and ezposed the cavity between the Internal Block work and external Bricks
The Gap is 3 Inches and there is No Insulation whatsoever :eek:
So i am looking at Wall insulation being installed
I assume its a foam thats pumped in from outside
What would the cost be for a 3 Bedroom Detatched House
Not Huge Built 1989
All i can find is companies advertising Grants for this work which i dont qualify for
Just want to see how much it is and get it done
Worcester Area
look at the websites of the companies supplying your gas, your electricity; and of your local council. If you are not a BG customer look at their website as well.
For example http://www.britishgas.co.uk/product...aving/home-insulation.html?bglink_id=imm10029
https://www.atlantic.co.uk/BeingGreen/Insulation/
http://www.tescohomeefficiency.com/cavity-wall-insulation/
They will probably have a free or a subsidised installation service. They will probably also offer loft insulation.
If not it will cost you a few hundred.
These days it is generally shredded mineral wool which is blown into the gap, not injected foam.
