- Joined
- 4 Jan 2009
- Messages
- 3
- Reaction score
- 0
- Country
Hi all newbie here just signed up!
sorry if this post is a bit long but i thought best to give as much info as i dont know many people with crystal balls.
I have been planning a rear extension/conservatory for a while and hoping someone could give me an idea of material costs.
firstly i am undertaking the build with myself and my father who has brickwork skills.
so labour wise i know the cost and i am sorting out my planning requirements with local council office and am aware of the fee's.
I live in a newer build house built in the last 13 years it is a 2 bed with garage to side which is joined to house but slight set in from line of house at rear.
i live in an area which used to be chalk pits so about half a foot down i hit chalk.
the actual extension will be 2.7 mtrs depth and 3.2mtrs width upto where garage recesses in, looking from back door of house the right wall will be all brick work approx 2.1 to 2.2 mtrs high.
the front of the extension will be bi fold doors which again i have sourced a supplier for and they will make to measure.
i intend to go as wide a span with these doors as poss but with enough wall/pillars each side to support RSJ above door.
final side will be french doors which the above company will supply and again brick work either side to support lintel above door, i have also decided to do a tiled roof (glass to sweaty in summer) i will be putting 2 sky lights in but for cost i will assume its all tiled with standard gutter around sloping from house down with standard pitch and add cost of sky lights later.
The base will be footings with 4 inch fill inside, 4inch insulation and standard top and screed, with walls having 75mm cavity filled with rock wall. (all walls standard brick)
above not exact a builder i know advised me of exact requirements for floor but i have to dig out my notes.
still a shot in dark i know but any advice on costing for above would be gratefull! sorry i said it would be long!
oh and im a security engineer so cctv, alarms, access, door entry questions ill be happy to help if i can
lee
lee
