I have a table tennis net bracket which is broken .. basically one part if like a G clamp and the other an L shaped piece of round steel (4mm diameter)
I was going to buy some 'chemical metal' to stick them together, but at about £7 I had second thoughts.
I have some resin and fibreglass, which I used for a campervan repair and have some left over ... and was wondering if I could use this.
I would clamp the sections together in the vice, then put the filler (with fibre strands inside) all around the two metal pieces.
Would this work ?
thanks !
Would this work ?
thanks !
