L
longdogs
I went to fit an immersion heater timer for a customer the other day. Affter removing the fused spur, I checked the live wire with a tester screwdriver (I normally do this to check that the bulb is working before switching the supply off). There was no power at all. I then tested a couple of sockets which were fine (screwdriver lit up) and then I tried testing the circuits at the consumer unit and found that no matter what the tester touched it did not light up, not even the main live cable into the house. Is it normal for a tester screwdriver not to light up when touching the supply cable? or is there a hidden problem somewhere?
Jobs finished now but just wanted to know for future reference. Thanks
