Could this be the processor?
15 Nov 2005
South
Cook Islands
I recently had a fault on my main PC, and dragged out the standby one, couldn't get a display and decided to bin it.
While I was browsing ebay to see if the remains would fetch anything, I happened to see a m/board of the same range as mine.
I bought it, put it in the case... still no display.
I fitted the known working PSU from my main PC and the known working AGP card (the m/b has on-board graphics as well). Still no display. I checked the case-to-mb connectors and am satisfied they are correct.
When I turn it on now, the PSU fan starts and runs; the CPU fan starts and runs; if there is a hard or CD drive connected, I hear it start up and skitter about. The HD LED lights for a while, then goes out after a minute or so. If I press the "reset" button the PC sounds like it is restarting (lights blink, drive starts up again and skitters). If I press and hold the Power On button it powers itself off.
Looks like it was a mistake to buy a replacemnt m/b. Do these symptoms sound like it is the CPU (Athlon XP 1800, socket 462) or the memory (P133, 2 x 512)?
I could buy a cheap Duron or something but am beginning to regret not binning it earlier.
Yes. Or a faulty m/board.
BTW, the skittering noise you hear coming from the hard drive soon after power is applied to it is just the sound of it thermally calibrating itself.
I very rarely buy a m/board without an accompanying CPU, even if second-hand. There's just too much ways in which things can go wrong otherwise.
Did you test the PSU before connecting it? :(
PSU: I put a multimeter across the two pairs on the IDE power socket, they had correct voltage across each pair (forget the number, was it 5.5v?) but did not try the 20-pin connector as i didn't have a spec of what it should do :(
I am considering the possibility that the old PSU might have a fault, possibly an overvoltage, which has caused some damage. Sadly I first tried the new board on the old PSU before swapping the known good PSU in.
When I remove the processor, memory and all drives, I still get no display with old or new m/b, although I see from my old notes that I briefly did get a display on the old board after resetting the CMOS.
I think my new PC (Sempron 2800+) also has a socket 762, if so I could perhaps try the old Athlon in here unless a faulty processor could damage the new m/c. However I will not put the Sempron processor on the old board as it is not on the makers compatibility list and I don't want to risk damaging it.
If you're going to be doing this kind of thing again, get yourself a cheap PSU tester (such as this one).
I can't think of any way in which a m/board without a CPU and memory could possibly put anything on a display.
Very wise. I wouldn't take that risk.
hi when u changed mb and tried a agp card did you go in bios and change setting for not using the onboard graphics? as if you didnt you wont get alot on the screen . or if its an old mb change jumpers ?
can't change the bios as I can't see it.
No reference to jumpers for display in the m/b booklet.
But I reset the m/b CMOS so would have expected it to set itself to onboard graphics.
yes, by connecting it to another PC.
it is an old CRT monitor so unlikely to be a compatibility or refresh rate prob.
JohnD said:
... Could this be the processor? ...
Yes... it was :cry:
I bought a used barebones cheaply, it ran with my old memory, when I swapped my old processor into it... no display :evil:
The vendor threw in a spare processor with a couple of bent pins, I might try hammering them back to shape to see if my old m/bs work now.
