Hi I've got a baxi 105e , everything seems to be working well , only problem is it has a funny buzz that lasts for 3 seconds , this noise happens 22 seconds after the fan has stopped . it sounds like a solenoid any ideas what's about to brake ?
Could be the fan, could be the casing,is it definitely coming from boiler? does it do it when turning hot water tap on somewhere? Hard to say without more exact info.
It is coming from the boiler and doesn't happen after hot water been on . I phoned baxi and they told me if your gas safe guy says its OK believe him .
