- Joined
- 11 Sep 2007
- Messages
- 769
- Reaction score
- 31
- Country
Need to fit a counter top basin, ridged type with 1 Tap hole, that will sit on a vanity unit, these is a plastic bit that goes onto the basin (same shape) to conceal any pipework...
It was supposed to...but did not come with a template for holes etc, they can not get this to me till thursday and need to do it tomorrow.
I am assuming that if i put the basin on the top and mark where the waste will go and drill this with a larger hole drill this will be fine? However what about the flexis to the monobloc? Should I just drill 2 small holes slightly back from the waste hole to feed these through? The plastic will hide it all?
The monobloc has also been supplied with a pop up waste, will this work with this type of basin, as I need to get the rod down to below the wood to fix to the waste?
Hope all this makes sense and you are able to help.
Cheers guys
Cheers guys
