I've googled the type of window I have and it appears to be a PVC, double glazed awning window. It opens from the bottom and has a handle/lock.
A few issues with some of the windows:
1) one of them shuts, you pull handle down to secure however it can be pushed open whilst the handle is in the "locked" position. This means that if it's really windy outside, it can sometimes blow open of it's own accord.
2) another window you open, leave say, 5cm ajar and it very easily and with little resistance will blow open wider. I'd like it to just stay in that one place (obviously unless it's gale force winds which I understand you can't really protect against).
I've looked around the edge of the windows, the handle, the joints, etc... I can't see anything immediately obvious to adjust.
Can anyone help me fix this issue?
