Hi
I have removed my bathroom radiator and wish to fit a small towel radiator. I have purchased a 600mm width radiator and the existing pipes will match up perfectly as long as the fittings are the 'straight through' type. Howevert the system is fitted with microbore 8mm pipes.
What is the best way to go about the fittings? I can get the straight through type but all the ones I have seen are 15mm so some sort of reducer will be required.
I have seen these:
http://www.screwfix.com/p/solder-ring-fitting-reducer-15-x-8mm/64553?_requestid=81240
and have seen 'reducers' but do these fit to the 8mm pipe like a large fat olive?
Advice would be appreciated
Steve
I have seen these:
Steve
