I am intending to install a wood burning stove in my lounge which has no existing fireplace or chimney (with building inspection approval etc) but I'd like to cover up the flue as best as possible.
To do this I was intending to build a stud wall around the flue extending to the lounge ceiling. The flue will exit through the external wall somewhere between the stove and ceiling.
Clearly, suitable gaps will need to be maintained between the flue and combustible materials, but my nagging doubt is how hot things might get in the region inside the top of the stud wall with warm air rising from the flue and stove.
I hope to be able to keep the front of the wall as close to the existing wall as possible to minimise impact on the room it's in and hopefully reduce the effect I've mentioned above whilst respecting combustible distances.
My question to you knowledgeable people is have you seen this kind of installation before, or do you know of a reason it should not be done?
Many thanks for your help.
