Evening all,
I am simplifying the lights in my hallway and looking to covert the current lighting setup which is a 2 way dual gang switching solution to a 2 way single gang solution.
The current setup is:
Switch 1..................Switch 2
|.L1..L2........C....| |.L1..L2........C....|
|....C........L1..L2.| |....C........L1..L2.|
I just want o check to be sure that I can simply connect in the following in switch 1 (and then the same in switch 2):
- Both C wires can be connected to the single C connection on my single gang switch
- Both L1 wires can be connected to the single L1 connection on my single gang switch
- Both L2 wires can be connected to the single L2 connection on my single gang switch
Thanks,
Chris
Thanks,
Chris
