Hello
well started some coving the other day to find the internal corners/angles would not meet up...flush at top (ceiling), 10mm gap at bottom (wall) - so thinking it was my cheap mitre block we bought a proper coving mitre tool from wickes for £3 - its great..but result was identical..it was then I realised the walls are not true - two corners are GREATER THAN 45' and other two are LESS THEN 45'
what do you do when confronted with this issue....? ...anyone?
i tried marking 10mm at the bottom and cutting it flush to the tip (make more of an angle to meet it) but when you do that the tip and bottom are closer in too each other than the opposite corner your fitting too and means that only the top (ceiling) or bottom (wall) can be flush with the opposite one and the other not...
are there special corner pieces that can be fitted over the top to hide the discrepancy..?
im not filling it cos your gunna see it and it would look pooe..
help!
thanks in advance
help!
thanks in advance
