Hi, just moved into a new flat and it has a coaxial cable coming in through the wall from the aerial. I'm trying to wire it to a wall mounted socket instead of having loose wire. Thing is, when I wire it up I get a bad signal. If I revert back and put the original plug on the end of the wire and plug in to my TV, the signal is good again. So I must be doing something wrong with the wall socket. There is a screw for the centre piece of the coaxial cable to go and then a bracket to secure the wire. There is an exposed area of copper or something under the bracket that I think needs to make contact with the outer wiring of the coaxial cable and I have made these two touch each other when screwed in. Am I doing something wrong? It shouldn't be this trickey should it!!
