Crack in plastic bathg
17 May 2004
Hi
I have a small crack in my plastic bath, is there any way of repairing it and what is the best way around it, the crack is about 3 inches from the bottom of the bath and around 2inches long.
onesongrg
There are a few products around that may be worth a try - epoxy fillers and the like.
To be honest a 2" long crack low down in the bath is probably not worth repairing as there is always the risk that the repair doesn't hold and with the weight of a bathfull of water and a person it may break - in which case you are looking at a much more expensive and extensive problem - new ceilings / floors / wiring etc
Thanks guys for your advice i will check my policy see if it is covered.
Might be best to tell them that it happened since someone fell in it ..... =
Accidental damage.
If you say it just appeared you will hear the words 'Insurance is not a maintenance contract'
