I have a 4 inch breeze block wall (Not Load bearing) which we found had a crack right through it when removing wardrobes. had a builder friend look and after 6 months with tell tales on it - no movement. looks like at some time there mad been a bad leak from bathroom on otherside - some water staining. No damp now found.
Moving on now I am advised to clean the mortar away 6 inches either side of the crack - drill 8mm holes into the crack 3/4 way through block from the accessible side at 100mm spacing and inject masonary fixing resin, then fix mesh and plaster over.
Query - Is this sound advice.
What resin to use? From screw fix - Tarmac and masonary resin recommended.
