Cracked Asbestos outhouse roof shared with neighbour
23 Aug 2010
Coventry
I have an 1950s outbuilding that shares an asbestos corrugated cement roof with the neighbour. It has two skins with a gap of about 25mm between them. There is a massive crack in an outer panel on our side and a massive, bowing crack on the inner layer on our side.
We would prefer to take it down ourselves taking necessary precautions as outlined by HSE but the problem is it is integrated with next doors roof.
This means we could easily take off the top layer from our side, but then we would need to cut back the neighbours panels (I have already spoken to our neighbour - housing association and they will do nothing about there side) which overhang onto our side by about a meter. Then we would have to cut through the inner layer composed of more overlapping panels.
I would really like advice on whether we should pay to get it removed properly or could we put up a framework for a new ceiling inside that would support the bowing panels, and just replace the easily removed outer layer. The cheapest solution, but would it work longterm?
thanks
ps, we don't have much money.
The roof:
- slopes down from our side to the neighbours
- has two skins approx 25mm gap between.
- the panels overlap lengthways.
---- Put up the framework and seal over the crack with some gunk ;) The issues with H+Safety / asbestos-cement / Housing association owned property. Really prohibit you messing about with it :cry: . If it was your own shed in isolation it would be a different ball game
A photo would be great to see whats going on ! do you have a digital camera?
