AGA and immersion heater heat the hot water.
AGA supplies heat via two connections at rear of HW tank
Two water tanks in loft: CWS and F/E.
The F/E overflow drips outside and the valve does not seem to leak.
The CWS valve dribbles (replaced 3 months ago) and does not shut off by water level alone, IE I can lift the ball and it will shut off.
One pipe (feed) from the AGA to the HW tank is warm but not as hot as
usual, the other (return) is cold instead of being warm
With the IH turned off the AGA does not heat the hot water in the HW tank, when the IH is used to heat water, the heat drains away.
The shower drips (hot side) and I am replacing this in the next two days with another new valve.
I seem to be replacing parts of this system which was installed 30 years ago.
One toilet
Four taps
One Immersion heater
two gate valves
One Ball valve in CWS
To do: shower valve.
If it is the coil what tests can I do?
Are there any other considerations beyond getting the same size replacement tank and to switch off the AGA and to drain the AGA water system and to also shut off and drain the cold and hot water systems?
Is the best way to drain the hot water cyl via a downstairs hot tap?
One toilet
Four taps
two gate valves
