Hello,
When we purchased our hose a couple of years ago, we had a line of cracked tiles in the hallway. I'm in the process of decorating the hallway and have decided to address the cracked tiles.
Today, I've remove the 3 cracked tiles and have found the root cause of the cracking. It appears the floor was laid in 2 separate pours and there is a seam directly under where the tiles cracked.
I assume since the floor was laid there has been a some movement, however, in this scenario I have read that there should be an expansion joint up to the surface of the ties to prevent the new ties just cracking again.
Here's the problem:
Here's what I believe I need:
http://www.wallsandfloors.co.uk/til...-Movement-Joints/Heavy-Duty-Beige-08mm/14972/
Is this the best course of action here? Anyone any experience with this type of joint?
I will need to cut the tiles to fit the joint (as its part way through a complete tile) - Will a good finish be achievable? I assume a 8mm depth as my tiles are 8mm thick.
Thanks in advance![/url]
Here's the problem:
