Cracked floor tiling
15 Jul 2005
Help...advise please !
Have a new house...one year old. Decided to push the boat out and get the upstairs bathroom and ensuite completely tiled ( wall and floor ). We used the builder's recommended tiler...both builder and tiler have subsequently been fired by the developer
The problem is that the floor tiles in both areas have cracked....I would imagine that this is due to the little s*d not putting anything under the tiles on top of the ( what looked to me like ) chipboard. He has offered to come back and replace the broken tiles, but this seems like a waste of time as these are surely going to crack again. He is claiming that there is slippage in the floor itself. Am debating as to whether it would be sensible to rip the whole lot up ( tiles and board ) and replace with a decent base or just to take up all the tiles and reinforce the chipboard.
Any thoughts/suggestions would be very much appreciated
If tiling over a wooden fllor 18mm ply should be used to provide a stiff enough surface for the tiles. Also, a flexible additive must be added to cope with the last few nanometers of movement. Chipboard is a **** surface to tile on. Rip and start again with WPB ply underneatn, possibly taking up carefully to save as many tiles as possible to re-lay.
Thanks.....was hoping not to have to rip ot all up, but I guess its the only sensible option....tiles are pretty much bu**ered as more are cracked than not, and if i do this, I only want to do it once
Thanks for the advice
stonefix adhesive will do the job, highly flexible.
you can take up tiles, then use 15mm ply onto the chipboard to re inforce.
or
you can use 6mm hardie backer boards www.pureadhesion.co.uk which are as strong as 15 mm ply, also waterproof
or
you can pour 5 mm of mira x plan self levelling which again will re inforce the floor.
You don't need to take up the chipboard, just strengthen.
mattytiler, the powers that be on this forum frown upon replying to old posts. As the post you replied to was over two years previous you'd think they'd have sorted the problem out by now.
Cheers...
p.s. do you have shares in that website you keep plugging? ;)
