Hi
I hope someone can offer some advice.
We had an extension built 13 years ago, by decent builders who met building regs.
There is a bathroom in the extension.
The shower area is in a corner and both walls can be seen from the exterior of the property
Over the last 6 months we've noticed cracks in the tiles and you can now see they are coming away from the wall (protuding outwards, ie not flat)
Initially this was seen on the shower side but not the other side of the shower corner wall also shows signs of cracking/tiles protuding out.
I inspected the exterier walls and call see small cracks 1-2mm in the rough area where the cracks in the tiles are.
Unfortunately we are unsure when the exterier cracks became visibile.
We are going to have to re-tile the shower area (maybe use a shower panel instead as matching tiles are unavailable).
My concern is that if there's movement on the outside this will again affect the tiles once it's been re-done.
What should i consider, ask, do?!
many thanks
many thanks
