hi,
our house is end terraced, and we have a vertical crack near the centre of the gable end running down the internal wall only (no crack on the external). the crack meanders a bit but basically runs vertically.
the wall is wallpapered, and when the house is heated, by the central heating or just on a hot summers day, the crack reduces in width. this shows itself as the wallpaper raising slightly along the crack. when the temperature is cooler in the house, then the previously slightly raised wallpaper sits back and flatens against the wall.
the change in the crack width (shown by the amount of wallpaper raised along the crack, i guess) can happen pretty quickly. for example, with a cold house on a winters day there is no sign, but after just an hour or so of the heating on high the raised wallpaper occurs, and gets more raised as the heat rises.
the blocks on the gable end internal wall are a thermal type, and the external wall (which has no signs of cracking) is brick.
any advice would be greatly appreciated, as i've trawled the net for an answer, but to no real avail.
thanks.
thanks.
