We had a downstairs supporting wall removed, acro props and steel beam designed by structural engineer.
A week later have noticed some cracks in the plaster and corner of the door frame upstairs, and the wallpaper has moved apart on the other side, and while the door will still close it won't stay shut like it used to. This is just beyond the end of one of the padstones at the end of the beam.
Is this serious? Is there likely to be further movement? Don't want to remove the plaster to see if the brick wall itself has cracked but will if necessary.
View media item 83183
View media item 83184
