Cracks appearing in paint. Is plaster sealer the answer?
31 Aug 2006
Hi all,
I stripped the wallpaper on the walls that I am decorating and used sugar soap to wash them down.
I then filled holes with polyfill and used Polycell smoothover on the rough areas. I then sanded it all down.
Then next stage was to add a coat of polycell base coat for walls.
I then painted a matt colour on top of this from the B&Q colour range with a roller.
The problem is that hairline cracks are appearing on the final coat of paint.
I have tried sanding it down and re applying the paint but the cracks just appear again.
After reading the instructions on the paint again I noticed that it says that if painting directly on plaster, a coat of plaster sealer should be used.
This is a step that I missed out and I think is maybe the reason that the cracks are appearing. Can I now just paint a coat of this plaster sealer on top of the paint that I have already put on the walls? And then put another layer of basecoat followed by the mat paint on top of the plaster sealer?
Or will I have to strip off all the paint I have put on so far?
Thanks for advice.
I'm not too sure. I think I only noticed them after the 3rd coat, but maybe they didn't have time to develop after the other coats (before the next coat went on.)
