I boarded out my loft with T&G chipboard a couple of weeks ago. I've now noticed cracks in the ceiling (I think they were there very faintly before). I presume the plasterboard has flexed as I walk upstairs - should I be worried or just paint over?
No - boards screwed and countersunk. Loft is just to be used for storage (will probably only be up there 2 or 3 times a year.) If nothing significant, should I do anything special to these cracks before I next paint the ceiling?
The correct name is ceiling binder which is normally a 100mm x 50mmm section, placed in the centre above the ceiling joists to stop the ceiling sagging in the middle and is supported on the end wallplate or top of wall. The board hanger joist is a nickname we use
