Cracks in exterior render
4 May 2007
Hi
My parents in laws house has some cracks in the exterior render which I wanted to patch up and touch up with paint. See the two cracks below (on the second closeup picture it makes the crack look quite wide but they are only one to two mm wide).
Can I just use an exterior caulk like this https://www.screwfix.com/p/no-nonsense-exterior-decorators-caulk-white-310ml/9735h ?
Thank you for your help
Side of window
RT-dxq0M2Kchq8pwIl6RD8qWwsbUKXVVe4btMzQej5E0dVemAK66cTDTW5zrzeYxbpuhHx1eVffBacSB2ynZNoBFYOIJRGDLgQV7yvWm3w36o_Mtel_P_4DIOsNocF1k_tdniFfSlk2Zz5FLkCYex-7w4xDUV9h6qnbC5K1pzotHAkakwq4qr1QPdEoLKnSDZHHO89hrSdcAqlJ7pZuo-gmvAvHAqxmEDXFQI9_GANYgIDtS-6E-uxRtXgCeIR0_L9rPO348htE1scyeLaEQx8CoNAYhN4BBT0GXeoLWRRXNSaeE3yeFo96zmp4_g_VlpjzHrHZ8GnUq-TBZV1pJAjPKVrCHQ3wX8owcDTb3TAZGIlUq7uIpOg71eibQRrgJ-UknAWve8kYPhjZANkAQmE3pqcm-mNnAjukiEyKtA6dU6cPEy9kmLDm7wc1MzD-9_NQ2CFk1vhrWmg6FvaOUc-JopueBC_ZE6xC8rs3bJzPXLyRUYdVKmTbimYHEX1UNa1SfnDX4rAbZUlyM6MwtqtLfMrqCxsRgt2zr_DK5ychyGgkWDUpHznip3deZSfwYY2ZIZbKI_O0lSpoafdEvpvcr1Om10tioVq25NSyO7WfuxFero56Njv5HoA9vUIvWARuNCl2J2UsR0mBc4Dfm64Sof8qcvGI=w408-h723-no
Side of window closeup
k5VxFP30QGOnhooJQxHBWQKlY2zuQfsZZ_Ju8--rc5-El3coYWZSLueIbCLCjwlVmt46gn4ZL2m6n-z1sAsy65aBhPp2q5W90Q_BcZGDkzNZwNE0NcWWc-6j0Eyz_Fs7DsK91gT1kGkduLdl-SW7pUzMDqEzZplqTHx91d0S7MXicFS4Sjfed3Dc0RT3anyV4vuwbVPGkTacC8weRWnu22hc1xgaTt0WH7tSh914fUKYBRc5eibirmqYAXv2s3RnFTnGxXmv6Ex23SRksr2D0S6Gxp3iMtZx-W9mvfPWBzYQ8TOD6bOe918pWdvQ_BwbCvvk29kaAM9qDcF10IB_2Gk34CaRp_vYwqngU6jJHED8bvp9YmEI6eKNSsMdpQFy98XMd7g8NOcpMeGlzPzlemU3S97Sc8UlzFiCpa-EZgUFS7JEEvM-TmjQjw9f3L6EmW9VY3RhSFdlJC_VdsQNYrop3gIQFJdlnDH2AA23v-dVFP5MFe5RXpqXsM0g6oBUvmOs3HbUyYkQfb1Nm645zTqXUECiP6oGjACMGwgYBnEb4RPL5Jsz0XQnegFxXom9EJvDppQsdw8WF8kuUtIaywvWBEOsknELJux7u0fg6PsdVlrktpstgXtojM9ffeaSMV369yZXCFvfLjKndZWFde2tFwGzLJY=w408-h723-no
Above window
Xz7P2WyqBz6GZRCADY5PEDjTy26TsJd6RJVMqfzfFKJufRQA2j-5oym3uejuU3t2oPy8DKLAZP78JwXCODnaCnN_TtVpait48BB4LNPNPSnMFnVTLV8_YjxWIAkbeiIBNhkTDvvp9kx9E0VDvFbKM518NkBr5phfzSjMz9DXnb9_bRXLj4rvfNk_AJpNLaLZ5YJJ8RU4fHFfUI3Bp_2vbQjBfcTHdaPo-5gLtmLDUx14JXfPHGEoX35H50oTCshKnqSoQStUwCpzJkcruEyB1yj7xZwAMQUoNKu-EtkpgMG-_5PC5HhUWXzK8sBUTx1fUisNHAUOZLVhLZawHL2135nfW8NTfGkoazAu9XhmvaVWEj_-6S2efWAibmmEf-R1oZRi2Kf8mWuJ3VfZmZSHNFkhT-F_psQ9ZbZ0PT4Bn5SPVFt9nGzKw6mhsjZTGlRoAV6M8AbszA3ubKVrMJCZbaF-Q5aj4AMGYHE_R0Xm_iSId7toQsade-FPK-yo_DF7-v7u55DKaiD2MyEsxV7IaG6BX5fFOWmUXN3sODtT56CPIibe07jp88PxdzgiHNAv12wiuIIFjrlo7BNe91nFcCH7QSHp2bVTntnzEsd4MKDSyS9bIgYm4q_BLsU9HKU0VCGhGWJdPnXSl67GW_FWNlA_saXAQUY=w408-h723-no
Image 1&2 (and possibly 3), I'd use a MS polymer, eg, Stixall, CT1, Sixaflex. You need to apply waterbased paints over them before you can apply oil based paints. They are almost as flexible as silicone sealants but have the added advantage of being paintable.
In image number 3, once you use the MS polymer, after the first coat of paint, you may want to throw some sand at the first coat of paint to hide the new smooth line.
A tube will cost £5 to 10 but they are very sticky, I'd recommend buy some decorators' wipes to clean your fingers after (price £5 to 10).
Standard caulk will shrink back and is more likely to crack again. It may suffice but do you want to risk having to do the job twice.
If, for whatever reason, you don't want to use a MS polymer, Toupret make a caulk with fibres to resist cracking (Fibracryl- approx £8), it will shrink though.
