As can be seen in the picture below i have cracked mortar around the lintel which spreads to an upstairs window. No bricks are cracked. I just got home from working abroad and noticed this. I'm having a few weeks off before I find another job (self employed contractor) so I'll be doing the repair myself in my free time.
Im just after a little guidance for the method of repair here. I assume prop the wall in say 2(or more?) places and then rebuild the lintel and rake out the cracked mortar and replace? Should I put in some steel above the brick lintel to strengthen it up? I was thinking some angle iron in the mortar on the inside of the cavity 50mm x 50mm x 4mm?
[/img]
Cheers in advance
[/img]
Cheers in advance
