I have some cracks on the inside and outside of my pine, four panel Victorian front door. Mainly around mouldings etc. the worst is in the muntin on the right hand side, it is about 2mm at the top and in the middle 4mm (see pictures below).
A little bit has come away from the middle and there appears to be nothing inside? Just a big gap. It looks as though this crack goes all the way from top to bottom and has been filled in the past? maybe when it wasn't as bad.
A neighbour, 7 years ago had (for the previous occupants) removed the door, stripped all paint with a blowtorch and repainted. I think it was just one coat of gloss on the outside and I'm not sure about the inside.
I bought some 'Liberon Wood Stopping' but I have since found out that is only good for INTERIOR and I have cracks to the EXTERIOR. They also do 'Liberon Wood Filler' but when I rang technical they can't tell me if either can be PAINTED.
It says it is water based and flexible which I gather is what I need to stop it from cracking again. What is best to use?
Also, the bottom left hand panel is cracked. From what I gather the only way to fix this is to remove some of the bolection mouldings, take out the panel, glue and clamp it then replace..
Advice would be most appreciated - thanks!
