Dear All,
I'm new to this forum and came across this beautiful website when I was searching for cracks in wall of house. I'm planning to buy a house, which is going to auction next week. I've done the building survey today and he says all these cracks are cosmetic and its not a problem.
House is built in 1957/58
House was extended later may be in 1980s? to create more bedrooms
please note that these cracks are appearing only at near first floor of the house and nothing is visible near the base of the house.
rear side house inside cracks:
I've seen crack in extended bedroom below the window. also I've seen another crack in the same bedroom in the corner ceiling, which is 40cm length and crack width could be 1cm! I've not seen any cracks outside the wall. All these cracks are at the rear side of the house that too inside.
front side house crack
but I've seen another hairline crack at the front side of the house but nothing inside that bedroom.
I've attached all photographs with this question. Could you let me know whether its worth buying the house or not? Surveyor says that's not a problem in building report but I'm trying to find out why there are 2 or 3 big cracks inside the wall?
near the crack, surface sound hollow when tapped.
I've very less time to decide so your response would be appreciated.
