Crashed Beko
11 Apr 2010
Isle of Wight
Hi all. My Beko 1715 s has crashed! We have a flashing Pre wash light, and can select different programs, but no operation when you press the play/pause button. Have tried all known reset options, ie; hold play button for 3 seconds, and child lock function but to no avail. Even tried turning unit on whilst holding play down. This just caused the play button to flash. Are there any other ways to reset this machine or is it time for a new mainboard? This problem occured after we started a spin cycle (by accident) then paused and changed to synthetics. (Main wash) It started to fill but thats it! Really appreciate any advice, thanks.
beko WMA1715
turn machine off select 90 deg cotton press and hold start, switch on keep holding start for three secs it will then flash
turn knob to spin press start light codes as follows
prewash .................................. NTC
main wash ................................no heat
prewash and main wash.............. constant heat
rinse......................................... no fill
prewash and rinse ......................no drain
prewash main wash and rinse....... pressure switch
main wash and rinse ................... tacho/ pcb
rinse and cond ............................ no motor action
to reset error codes hold start for five secs
Thanks for your info. I tried what you suggested and got the machine reset, but on further investigation it turns out that two transistors have burnt out! I now need to identify them as the ratings on them can't be made out! They are labelled T2 and T9 on the main circuit board. Any info greatly appreciated, and any ideas on where to buy; tried maplin but no luck!
Thanks, Carl
