Hi All
Had a multi fuel stove fitted about eight weeks ago. The fireplace opening was enlarged to take the stove and the installers finished off the plasterwork to a good standard. I left the plaster for a few days to allow drying out then applied matt emulsion with a roller.
Since the paint was first applied I've had problems with the surface crazing, but on only one side of the breast. The other side is perfect. I've tried rubbing down the crazing, sealing with bonding agent and repainting. I've tried taking off the plaster in the crazed area then replastering with one coat plaster and repainting. However, the crazing always comes back.
I'm tempted to leave things till the weather improves, take the surface down to the brick and start again, but it seems like a lot of trouble to go to just for a decent paint surface.
Is there any other treatment or procedure that I could try to get a decent finish? I initially thought that the crazing might be caused by heat from the stove, but if that was the case then both sides of the breast would be affected.
Cheers in advance.
Cheers in advance.
