your only gaps will close up with screws
you can use the foaming for gaps but unlike the the other one spills wont easily clean as its viscosity is like syrup so if you are going to use it selotape the gap at the back underneath so when you pour in a 1mm bead in front on top [will foam to three]it stays in place till you screw the riser tight
do not try and remove glue until dry unless on carpet or clothes
the foaming will go out off use quicker skinning up in the bottle after about six months the other one will last up to a year and dead easy to clean with lots off water
