Hi
I am thinking of creating an airing cupboard across the other side of the house. We have a standard gas boiler. I am planning on picking up on the feed and return hot water pipes and routing up into the loft across the house, down into the cupboard and back and connect to the return.
Possibly step down to 15mm pipes and make sure they are lagged and protected in the loft.
Is this ok to do? Means when the hot water is on the cupboard is airing.
The only thing that I am concerned about is if the rail in the new airing cupboard is switched off. I don;t want it to shut off the hot water or cause a problem.
Any thoughts?
cheers
Darren
Any thoughts?
cheers
Darren
