Creating a HDMI output for a Toshiba 43ul2063db TV main board
23 Apr 2021
I have a broken Toshiba 43ul2063db TV and the only thing wrong with it is a cracked screen. I'm hoping that there will be a way to take the PS and main video board out and create a stand-alone sealed unit with an HDMI output which I can then pass to an older TV so that I can take advantage of the board's smart TV software. Does anyone know if this is possible?
T.I.A.
William
Given that a Fire TV stick is £30-£50 depending whether you want the 1080p or up to 4K version, and that Fire TV stick will outperform the TV smart features anyway, plus the cost and complexity of trying to convert the screen drivers and integrate sound in to a viable HDMI feed that will also comply with HDCP content protection for any licenced smart streaming content....
Can you see where this is heading?
Cut your losses. Check out the value of your TV as used spare parts:
  • the remote - £15~£20
  • T-con board - £15~£25
  • Power supply - £20-£35
  • Main board - £25-£40 - rarely required, but it still has some value
Coming back to your idea, if it's possible to do by a layman then there'll be a video about it on YouTube.
Thank you for taking the time to reply. You make a very strong argument :) I was just hoping it would be a simple task. I've already considered the dismantling and selling the parts on Ebay.
Thank you again.
Kind regards,
William
