I have a clog in my kitchen drain. I have bought a high pressure manual water blast/suction "plunger". However, I cannot create a sealed pipe, as there are two sinks, and also two outlets for the dishwasher and washing machine.
I tried to unscrew the various compression fittings, and block them with tape/plastic bags, but those don't hold under pressure, so the plunger does not work and water leaks everywhere when I try.
Is it possible to buy some 40mm screw caps to replace the various traps, and temporarily seal the pipe while trying to unblock it? Otherwise, how people seal the pipes before high pressure cleaning/unblocking?
Even if I call a professional plumber, how will he/she do pressure cleaning of the drain, apart from cutting the welded section and connecting a hose directly there?
Thanks,
Tom
Thanks,
Tom
